Discuss What do I search for on Amazon: WIFI continuity Switch No current, no load in the DIY Electrical Advice area at ElectriciansForums.net
dpressm
I have a bathroom fan with a moisture detector that turns it on and off. It also has a control circuit to turn it on/off when moisture is not connected. This is a no voltage/no current circuit.
I want to add a parallel control circuit that would of course be no load no current that I can turn on/off by Wi-Fi (Alexa) - I realize that operating current (5v or 12v) would also be needed. I need to know what to look for on Amazon to get a switch that operates like as described. I link(s) below that shows one I think will work.
Generically I thought this type of switch was called a "dry contact" (with WIFI) switch but I get all sorts of switches in response to that search. Most show loads on the output - would any switch with an external power supply work the way I want simply providing connectivity even though the "Load" across the output was in actuality zero?
Thank You
FYI I need this switch so I (or more likely my wife) can tell Alexa to turn the bathroom fan on for x minutes - she says some times my S*** does stink!
Reply to What do I search for on Amazon: WIFI continuity Switch No current, no load in the DIY Electrical Advice area at ElectriciansForums.net
Im trying to make a Star Wars Prop for a course project where the dealine is comming up very fast in days and I need to do the report so really...
Hi All, thanks in advance for any guidance you can provide. I will of course turn off everyhing at the consumer unit before doing anything. I...
I currently have 2 ceiling lights in my living room that I wish to replace with 2 Phillips Hue lights. The current lights are turned on and off...
