Discuss What's the best Voltage for a Drain Camera electric? in the Electrical Tools and Products area at ElectriciansForums.net
Hi
Forum, I had drain cameras plumbing equipment and tools, I was just wondering how much voltage the right drain cameras would have if we converted them to electric?
Admin Note - cannot link out until posted ten times.. Many thanks.. Lou
Any idea is much appreciated.
Here in the UK for site work outside we would typically expect to be using a 110v isolating transformer (if I'm not mistaken, these are 55v-0v-55v, the center tap being used as the earth for the equipment connected to the secondary side of the transformer, with no direct links between any part of the primary or secondary connections).
Given you'll be working with water, the real answer is as low as possible whilst still being feasible. I also don't fully know what the laws are about selling things like this, but I suspect there would be a lot more hoops to jump through if you start connecting them directly/indirectly to a mains derived supply. You certainly shouldn't think about just buying a switch mode power supply brick from some supplier on AliExpress or whatever it's called because these often have one side of the output connected to the input and really that's not acceptable for this kind of environment.
Personally, I would avoid this unless you have absolutely no other choice because it increases the complexity of any kind of certifications and also increases your exposure when it comes to potential claims that could arise as a result of injury or death if the power supply went south and the camera was suddenly live.
Do you mean you want to run these from a main adaptor/PSU rather than batteries?
If so, what battery type and voltage do they use currently?
Reply to What's the best Voltage for a Drain Camera electric? in the Electrical Tools and Products area at ElectriciansForums.net
Hi, I recently moved into a house with electric storage heaters and am looking to replace them with electric radiators. Gas and oil are not viable...
  • Locked
Hi, I realise this is an electrical forum and not plumbing, but was wondering if somebody could help. My heating is not working and the heating...
4K
Hi all. I’m just wondering if anyone has done any work in Iceland? I’ve got a chance of going out there for a while. The work involves some...
6K
Hi All, I am looking for advice on electrical careers, i currently work in the access control industry of which i have a deep level of...
Hi Everyone, I had a new consumer unit installed in December 2021, the electrician said that he had more testing to complete and would come back...
