Search the forum,
Discuss Why do i need a rewire when i've passed inspection with no issues? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
davidc123
Hi
I'm having some work done at my house and the electrician has said we need a full rewire. I'm a bit surprised given that we passed an inspection 2 years ago and it raised no issues at all. We've just been told that the wiring is illegal and needs changing. Maybe i'm not understanding the point of the inspection certificate, but how is it possible for the inspection to raise no issues and yet it actually needs a full rewire? I've attached a page from the report, if it helps.
Also, I'm being charged £17k + VAT for a 4 bed house, which seems high to me. Is it?
TL;DR
Passed inspection with no issues but another electrician says i need a full rewire
There is no such thing a "illegal wiring". It maybe unsafe to varying degrees, but that is a somewhat different matter.
Have you go the rest of the test report (names/addresses redacted before posting)?
Can you provide some photos of the current installation, for example, around the fusebox?
To me this smells very fishy. First I would be asking the electrician for a written report on what points are failing inspection and the relevant regulations behind them (as is normal for a detailed EICR).
Thanks, i thought the illegal wiring comment was nonsense. I've attached other pages from the report and a photo of the fusebox
I'm not actually sure he looked at the fusebox though. He was more concerned about the wiring in the rest of the house, which had the older red/black colours
'Illegal' Wiring
Reaction GIF
Very curious about this one!
Do you have a page of the report that lists C1, C2, C3 and FI codes for the circuits?
It's not a Report. It's merely a certificate for replacement of the DB only, so the OP appears to be misunderstanding what it is stating. It relates only to the work carried out and does not declare that the installation is fine.
That's an EIC for a consumer unit change rather than an EICR
Ah OK, that's where the misunderstanding is. Thanks for the help.
On the other point, is 17k+vat a reasonable cost for a 4 bed house? We're having a new kitchen / diner, utility room and play room fitted too, so new points as well as a rewire of the house
Depends on the property, the spec of what you want, your location, whether it's occupied or not.
I'd get another quote though rather than rely solely on the electrician(s) that have said your wiring is illegal.
Reply to Why do i need a rewire when i've passed inspection with no issues? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
Hi all, I posted here some time ago asking for validation of a quote I received for a rewire. (10k assumed 60 points) And got some good advice so...
Hi, First time buyer here who is purchasing a 1970s 3 bed semi detached. No idea about anything electrical but the vendor said the electrics are...
4K
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
I'm getting an old fuse board upgraded in an office block. The electrician has just told me that most of the circuits don't have earth cables...
4K
