Discuss Why gas boiler want fire using solar hybrid inverter in the DIY Electrical Advice area at ElectriciansForums.net
Kincius
Hi my name is Gintas I connected solar hybrid inverter to my house ring supply and it work very well everything except the gas boiler for on demand hot water, the radiator heating works fine any idea why boiler want fire when I open the tap?
Flame detector
Earthing system
This is a complex issue and you need to get it installed correctly for your own safety.
I believe a solar inverter or any other microgeneration device needs to be on it's own circuit, not sharing a circuit with any loads.
Not sure that's relevant to boiler but it does indicate that other issues may have been missed in the install.
Hopefully there's an AC isolator between inverter and house wiring. How does the boiler work when that's switched off?
Regarding the boiler itself, does hot water require a permanent live, not needed for heating?
Reply to Why gas boiler want fire using solar hybrid inverter in the DIY Electrical Advice area at ElectriciansForums.net
As a young man, I was an electrician, but now I'm getting on, I am strictly DIY. I used to have a cheap old 900W petrol generator connected to a...
Hello, I am asking for a double check on my project before I purchase any electrical parts. My inverter Solark 15k has a built in 200 bus and...
At the moment it depends on the weather on how well the central heating works, the main problem is the Nest Gen 3 thermostat only measures the...
