Search the forum,
Discuss Why is my conduit bend passing so far from obstacle? in the UK Electrical Forum area at ElectriciansForums.net
I’m an electrician trainee and very new to conduit bending.
So the length of the floating wood is 9 1/2” and the height is 10 3/4”
I’m doing a 30 degree bend with multiplier of 2.
I marked the first mark at 9 1/2” then from that mark I measured 21 2/4”, but it just passes to far from the wood that is standing straight, which am doing a 90 degree stub up
Am I suppose to bend it at 45 degree instead of 30?
Reply to Why is my conduit bend passing so far from obstacle? in the UK Electrical Forum area at ElectriciansForums.net
I am adding a 60 AMP subpanel for a detached garage/workshop with a 200 foot underground conduit run from the main panel to the sub panel...
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
Hi! I’d like to install a pedestal-mounted (230 V, 30 A max - programmable) EV charger close to my driveway, which ends about 12 feet away from...
4K
Was wondering if the gurus can critique and/or provide recommendations on my plan to install two sub-panels in a (50'x100') 5,000 sq ft steel...
Hey Just dropping this question to anyone that's passed the AM2S. Could i get some clarification on what the AM2S specification require's for...
6K
