Search the forum,
Discuss Will 4 pin phase converter work with a 4 pin 3 phase compressor in the DIY Electrical Advice area at ElectriciansForums.net
will_505
Hi, leading on from my question the other day about running the 3 phase compressor off my 8.5kW generator I have since got my hands on a 240v to 3 phase converter. My question being the 3 phase output from the converter has only 4 wires/ seperatly cores coming out where as my compressor currently has a 5 pin 32amp 3 phase plug on it (were going to change it to 16amp as the guy I bought it off fitted a 32amp plug for convenience because all his sockets were 32amp) it is a 5.5hp electric motor so 16amp should do fine I think. But my worry is with the compressor having a 5 pin plug and the converter only having 3 wires will it work? We've an electrician coming up to do the wiring for us tomorrow but I wanna know if it's going to work before I go and pick him up.
Thanks in advance.
Will 😁
Reply to Will 4 pin phase converter work with a 4 pin 3 phase compressor in the DIY Electrical Advice area at ElectriciansForums.net
I have a small mechanics shop in a rural area with no access to 3 phase. I picked up a air compressor cheap and knowing at a min. I will need a...
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
Hi there, I've got a 3 phase compressor and a small 8500W single and 3 phase generator. My compressor has a large 32amp plug on it but my...
I have an old Migatronic Automig X 200 welder configured as 380V 3-phase unit. Migatronic for spec. I have a 220V 3-phase point in my garage...
