Search the forum,
Discuss Win10 always have WiFi disconnection problem in the Computer and Networking Forum area at ElectriciansForums.net
Does turning just the Wi-fi off and on not reconnect? Rather than the whole computer?
Normally dropping out is down to interference. Thick walls, electronic devices in vicinity of either router or computer. (Meaning microwaves or fluorescent lights.)
It may also be down to the router itself. Can you ask your ISP for a new one?
Ive been through 3 or 4 the time I’ve been with my company. The power supplies seem to die, and the router doesn’t get the voltage it needs and intermittently shuts down.
Win10 always has a WiFi disconnection problem, restart the computer to reconnect, how to do?
I have been using Windows 10 for about two months now since my old computer packed in . I have the same problem as you have , and have to take the same action as you.
I have a dongle connected to 3 . My old computer never had this problem , but Windows ten drops out multiple times every day that I am on the replacement . Both are/were Dell laptops
Most of the time this problem is Windows 10 power saving but it is simple to disable...
If you open control panel and then select 'Network & Internet'
Then select 'Network and sharing center'
Then select 'Change adapter settings' which will show you a list of your network connections
Right click on the one corresponding to your wifi and select 'properties'
Click the 'Configure' button
Select the 'Power management' tab and untick 'Allow the computer to turn off this device to save power' and click the 'Ok' button to finish
If this isnt straightforward for you then let me know and I will add screenshots :)
Thank You . I will do that later. I have not bothered to go into any settings yet . I have taken an instant dislike to Windows ten.
Thank you so much! It worked!
Reply to Win10 always have WiFi disconnection problem in the Computer and Networking Forum area at ElectriciansForums.net
I'm considering using several of the remote WiFi switch sets to control a group of five different lights. The existing switches are all grouped...
Hi I'm trying to figure out how to swap my standard myson thermostats for WiFi enabled ones - going to start with the simple one first - the one...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
