Currently reading:
Wiring a 2 port valve on a hive system
Discuss Wiring a 2 port valve on a hive system in the Central Heating Systems area at ElectriciansForums.net
Good afternoon
Im in need of some assistance on a job. A new central heating system is being installed (previously storage heating) and the customer has purchased a hive multizone kit. She wants to control her heating up stairs and downstairs seperate so would need zones valves installed. I havent had much experience with heating systems before and im needing some help on how to wire this up. Any help would be much appreciated
I’m not too familiar with the Hive multi zone kit, others might help with that. You would have to enquire with the plumber/heating contractor, as to what system they intend to install. I guess it would be a S-Plan, which is easily wired up, google the wiring diagrams. But it will also depend boiler type, and if/what hot water system there is.
So more info required.
Reply to Wiring a 2 port valve on a hive system in the Central Heating Systems area at ElectriciansForums.net
