Search the forum,
Discuss Wiring Emergency Exit Signs in the UK Electrical Forum area at ElectriciansForums.net
L
lex101
Hi All
I picked up a couple of Thorn maintained emergency exit signs to replace faulty ones in a retail park store and when I went to fit them, they only had 3 terminals, L1, N & E. The fixed wiring is in 4 core. Is there anyway of modifying the wiring to get them to work? I connected the permenant feed to the L1 and put a connecror block on the S/L.The fittings I normally buy have a switch line connection too. Any advice would be appreciated.
If the charging light is on then the fitting is working fine. What you seem to have is non- maintained fittings due to the absence of a switched line.
Sounds like non-maintained.
You sure there isn't a link missing between the permanent and switched phase terminals to run it as maintained?
Reply to Wiring Emergency Exit Signs in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
Before I pay an electrician to come check my work, I thought it worth a post here. I don't want to pay the cost of a small car for a whole-house...
I was called to a hall where 6 Ansell maintained exit signs were all dead. They were installed 4 yrs ago. The one that I checked had mains live...
Hey, I lifted a few sockets from a wall so I could paint without having to cut in around them. I haven’t lifted any light switches yet. When...
Hey all :-) Hope its chill that I'm here asking questions, I just inherited this old decrepit place in NSW (Australia) and went to wash my hands...
