Currently reading:
Wiring Schematic - Solar Panels Installation
Discuss Wiring Schematic - Solar Panels Installation in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Riaansco
Good Day,
I Am completely new to this, if someone can verify my wiring diagram attached for the specs mentioned below please?
Here are the specs for the Inverter and Solar Panel. I Need to connect 12 Panels.
5Kva Inverter
Inverter Mode:
Rated Power: 5000VA/5000W
DC Input: 48VDC, 117A
AC Output: 230VAC, 50/60Hz, 22A
AC Charger Mode:
AC Input: 230VAC, 50/60Hz, 35A
DC Output: 54VDC
Max. 60A, Default 30A
Solar Charge Mode:
Rated Current: 80A
System Voltage: 48VDC
Min Solar Voltage: 40VDC
Max Solar Voltage: (VOC): 145VDC
_________________________________________________
Panel Details:
Nominal Maximum Power: (Pmax): 365 W
Optimum Operating Voltage (Vmp): 39.8 V
Optimum Operating Current (Imp): 9.18 A
Open Circuit Voltage (Voc): 47.2 V
Short Circuit Current (Isc): 9.75 A
Maximum Series Fuse Rating: 30 A
  • Wiring Diagram1.pdf
Reply to Wiring Schematic - Solar Panels Installation in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
