Search for tools and product advice,
Discuss Wiring sky tv in domeatic property in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Good afternoon
I was looking for some advice on wiring sky tv in a domestic rewire job.
Im inexperienced when it comes to aerial work as it was never covered in my apprenticeship but the client has specified tv points throughtout the home. Ive seen some wiring diagrams online but was hoping for some help by anyone on the forum who has knowledge on this.
Like i sat ive never had to deal with it before so any guidance would be much appreciated
The other thing I would add with Sky Q, is consideration of the Wi-Fi signal if its a property with thick walls etc. Sky have to install hard wired booster Wi-Fi boxes with cabling, in such instances.
What kind of Sky system is being installed?
Normally I take twin coax from each point to an agreed location for the dish installer to deal with.
Removes any future call outs for bad signal from the equation.
Thanks for the response. I was looking at some drawings that said tou
Sky q is just twin sat from dish to main box/tv point. Additional boxes are wireless.
That sounds easy enough. Thas for the response
[automerge]1578332453[/automerge]
So just run a cat 5 from each tv position to the router aswell as the sat cable?
[automerge]1578332636[/automerge]
Im not 100 percent sure what kind of system is being used i just know the main contractor wants it future proofed. If it wasnt sky q being used would i need to run coax from an amplifier in the loft space?
I think you need to ask what spec they require. As already mentioned Sky Q is different to Sky. CAT 5 or whatever the latest spec is, to each tv point. What about AT cable for internet connection. The list can be endless, and you can't really future proof, 'cos things change quickly. Ask them to specify, then you can't be blamed if something is missing when the property is handed over.
What I would do is run 2xtwin coaxes and 1xsingle coax to main tv position from a central position/loft, run a twin coax and single coax to each additional tv point. Also run a cat 5 or a couple to each tv point from hub/router position This would make It adaptable for traditional TV, sky, sky q, smart capabilities etc. If there is virgin in the area then it might be worth running a twin sat from central position to outside at low level as well. Use good quality cable.
Thank lee
And would all the cables your run back to an amplifier /booster in the loft space? I was going to use wf100 coaxial cable as ive heard its good.
Once the hard drive was added to Sky boxes each non Sky Q box needs two coax (shoot gun) from LNB to where the box is.
Freesat and Free to Air normally a single coax LNB to set bottom box.
You can't daisy chain satellite boxes, each one needs it's own cable, there was a system using digi eyes so a single Sky box could be controlled from many rooms, however it used analogue signal which was OK with 14" TV but useless with 32" or larger, the same applies to SCART leads, they are not good enough for modern large TV's.
In the main you will have a quad or hybrid LNB, you can get 8 output but need a larger dish, so in this house shoot gun coax to main room for Sky Q and 4 single cables to other rooms to use standard satellite boxes, however the latter are hardly used because Sky Q is wireless to satellite boxes, only the main one has coax.
As to future proof, pointless, my old house is full of redundant cables, telephone points were fitted all around the house in the days when my time sheets were faxed in, but not used a fax machine for years.
Today all wireless phones.
My son put LAN cables to each TRV head, but by time he came to fit them, all wireless.
Put conduit or trunking yes, but cables pointless.
Reply to Wiring sky tv in domeatic property in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
Hi All Hopefully a simple answer I can relay back to Client. My TV engineer is away on hols at mo, so after bit of advice from others please :-)...
6K
Hello i've recently just had a re wire done on a three bed semi house, Ive noticed a few things im not 100 percent on ive spoken to the firm that...
5K
Good afternoon guys. Recently had to make an impulse generator purchase. Looking for some guidance to make my generator use both more flexible and...
Hello, My first post here so apologies for any mistakes/breaking of the rules etc! Ive tried to read the rules and think this is the right place...
5K
8K
