Search the forum,
Discuss WOWS on PS4 in the Gaming Forum area at ElectriciansForums.net
Does anyone play World of Warships on PS4? I played for a long time on PC but it looks like they have it now for PS4. Can you transition your profile from PC to the console version?
Cross play or cross save for WoW is not possible between PC and consoles, the games are based on the same premise but totally built up and designed differently from the ground up, the content is also somewhat different as you will notice if you play long enough.
You can however crossplay between consoles so a PS4 can play against a X-box player but that won't help your situation.
Reply to WOWS on PS4 in the Gaming Forum area at ElectriciansForums.net
https://www.walmart.com/ip/Minecraft-Green-Creeper-Body-12-Can-Mini-Fridge-8L-2-Door-Ambient-Lighting-25-2-H-9-5-W-9-1-D/2670909566 ok so let me...
I don't fit alarms as my main job but have fitted quite a few over the years whilst we were doing the electrics side of things. I usually fit the...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Currently I’m using freeagents platform for invoicing and it’s decent and gets the job done but it’s lacking a few features. Firstly I want to be...
A few years ago i fitted some plain warm white LED tape, inside an alu profile around a customers bedroom. Sourced from YESSS at the time...
