O
Octopus
Who is using what as a legal quote?
So you haven't got the latest regs, nor a tester.
i dont own a physical copy of bgb i have an old brb and bybI told you this twice, or do you not have a copy of the BGB to refer too?
Trying to connect 2x 10mm t+e cables up in to a 45amp pull cord on a deep pattress you've struggled getting a descent fixing on a crumbling lath and plaster ceiling is not my idea of fun lol
Is a 'descent' fixing one that comes down when the customer pull on it?
... a little below the belt, I know ... ;-)
... but yes, I've always owned my own copy. And test equipment.
Right between the A and the D matei don't know where that 'S' came from lol
Hmm, let me explain a bit more.
The shower is already in and working. It has an isolation device (cooker switch) located in a cupboard on the back of the wall that the shower is mounted on. Trouble is the water pressure drops occasionally causing the shower to thermal. This involves the person wrapping themselves in a towel and walking around to the cupboard, switching the isolator off and back on. Then they go back to the shower to continue. This is not ideal.
I've been tasked with fitting an isolator within the DDA/shower room, and just wondered if there are any specific dimensions for locating the pull cord. I can't find any myself, so thought I'd ask.
Two 10mm cables into a pull cord? Child's play.
not that easy, dave. all our street has the same problem. anyone flushes the bog, shower goes cold with the low pressure light on.
Leave the isolator where it is and fit a thermostatic electric shower.
