I haven't yet got the latest yellow regs, no. It's only been out a couple of weeks?
Yes, I have a full compliment of test equipment. Calibrated too.
Big Green Book!
Yay for me! I figured out that you're referring to the regs! Apologies for not spotting the acronym, but yes, I've always owned my own copy. And test equipment.
I would be also looking at approved Document M...Wetrooms for disabled can more involved than you think...Electric showers must not reach temperatures above 41c, thermo valves must be fitted to sinks to prevent the same.
Hmm, let me explain a bit more.
The shower is already in and working. It has an isolation device (cooker switch) located in a cupboard on the back of the wall that the shower is mounted on. Trouble is the water pressure drops occasionally causing the shower to thermal. This involves the person wrapping themselves in a towel and walking around to the cupboard, switching the isolator off and back on. Then they go back to the shower to continue. This is not ideal.
I've been tasked with fitting an isolator within the DDA/shower room, and just wondered if there are any specific dimensions for locating the pull cord. I can't find any myself, so thought I'd ask.
Two 10mm cables into a pull cord? Child's play.
Leave the isolator where it is and fit a thermostatic electric shower.
not that easy, dave. all our street has the same problem. anyone flushes the bog, shower goes cold with the low pressure light on.
Then that's the water boards problem to fix, they have to maintain a minimum supply pressure.
Or else there are ways to fix it,
united utilities have been out. they say there's 3 bar in the road, and the problem is the supply pipes from road to the houses and in them. then again i trust them as far as i can throw them. the water supply is diabolical. reeks of chlorine like a swimming baths. can't drink the stuff.
Positioning of an electric shower pull cord.
Tug,
westward10,
TrueNAS JBOD Storage Server
