with bs7671 Amd 3 2015
is a henley block considered as switch gear and therefore enclosable in non ferous
I know it doesn't switch But an MCB wont cause an issue in the open position
i have never seen a melted Henly and its not the same plastic as the old CUs anyway
your thoughts ?
your thoughts ?
No..............
well it was a bit of a silly question, but, coming from luton, we can make allowances. :oops:
you didn't do a 6 year apprenticeship since July 2015 when the 3rd amd came in and that was the relevance of the question i rarely get involved in domestic but are having to add accommodation to an industrial unit.
ok, seriously, a henley block is not subject to any of the changes made in amd. 3.
Shut up Pete999 you will get a ban
If adding accommodation to an industrial unit which follows rules for dwellings under BS7671, would the work be notifiable ? I think it would be.
yes it is notifiable which i can do through my niceic membership weather i should is another question i have the qualifications and the membership of the club i also have a complete lack of ability and knowledge and have relied for most of my life on the supreme confidence of total ignorance
because i don't know i cant do it i assume i can
By the sarcasm in your response I assume you feel I was questioning your abilities and/or knowledge somehow, although quite how I'm not sure.
I wasn't. I was genuinely questioning the need for notification in such a situation as it is not one I have encountered before.
You want some work[emoji1572]
luton
use of Henley ?
Tags Tags
henley
belliezzz,
Amp David,
TrueNAS JBOD Storage Server
