I have been asked to supply sockets and a light to a detached garage and then onto a detached Pergola with a bar behind the garage a few meters away. The customer wants a couple of 2 kw heaters in the pergola area and a couple of sockets and lights. There is a spare 45A on the Rcd protected board. I intend to run 6mm armour cable into the garage from the House c.unit into a garage 2 way board. the question is, should I run into service blocks and back out underground to pergola with the 6mm to another 3 way board, and connect the garage board into the service blocks? I cant think how else I can achieve this. Any thoughts would be appreciated. There is another spare on the house CU but on the same Rcd at the moment. I was trying to avoid running two armour cables out and up the garden.
