Ta. I had an extra self-enforced few weeks off but couldn't resist a return. I am going to be on my best behaviour now, however I will still be monitoring the grammar, I have seen some shocking examples already, and I see George is no better.
Don't forget the spelling as well Mate, some of it is atrocious
Deleted
Would there ever be a time where not terminating the earth is acceptable? I have worked with a NICEIC registered spark and when it came to extractor fans or plastic one gang switches where there wasn't a terminal he'd say just cover the whole earth conductor in sheathing. If it was a 2/3 gang switch or any switch with more than one cable we'd use connector blocks but I would of thought that you would still do that instead of just leaving it disconnected???
Where would you connect them if there no terminal?
I feel for him. He's clearly proud of his work to show it to the YouTubes.
Unfortunatley my first thought with the D.B. was "Where's the 'Safety Electrical Connection - Do Not Remove' label on the externally mounted M.E.T.?"
Then I realised I should probably be doing better things with my spare time and assess my life choices right now.
Pete999
Northampton
Retired Electrician
Business Name
None
Quite a competent Sparky I think
Pete's Videos
Pete999,
Sparky Ninja,
