Please help. I have a basic understanding of electirics, but 5 Electricians are stumped and I don't know where to go next. My mother in law heats her house by 4 Night Storage Heaters, all of which are wired to a Economy 7 supply/fuse board, with no RCD just MCB. The largest of the Night Storage Heaters began to fail and trip the MCD. To cut a long story short, she ended up having a new one fitted. Unfortunately this new one also now trips the MCB. The electricians have tried swapping the various supplies to the various heaters around in the E7 fuse board and the same heater is tripping the different MCB. It would be an obvious thing to consider that there is a fault on the circuit between the board and the night storage heater. However, they have now wired it into the day time board and it is not tripping. Has anyone got any ideas as we need to get it wired back into the E7 circuit??
I can see the theory in the heat from the main switch in the E7 consumer unit on the MCB next to it that is for this particular NSH, however, I thought that this circuit had been moved to an MCB further along from the main switch and it still tripped.
My guns are bigger than ya's
Moving right along ...
Thanks for posting the update with the busted main switch. I'm still not clear on how this has caused a 20A MCB to trip quickly however, if I recall an earlier post correctly (?) .
Swansea
Totally stumped. Night Storage Heater tripping out MCB, but ok on daytime circuit.
Steve Poulton,
Darkwood,
