OttoF
Is there a safe and easy (but also precise) way to tell if two separate mains sockets are on the same circuit?
I need to know because I'm trying to use existing mains circuitry to create an ethernet network in a communal area of a multistorey block of flats, using Powerline Adapters.
Unfortunately, I can't just go flipping breakers at the consumer unit to test what stays powered on, as there is door access, CCTV, fire detection, etc. all connected to the main consumer unit.
It's a one-off job, and I'm on a budget, so professional (expensive) equipment is not an option, but I can stretch to buying a small bit of kit if required. I have some general DIY electrician tools (basic multimeter, etc.).
Any suggestions are welcome. Thanks.
P.S. using WiFi extenders is (unfortunately) not an option due to the location and lack of mains sockets, and I'm desperately trying to avoid running network cabling as a solution.
