OttoF
Today I've been working with an old emergency bulkhead with 26W 2D 4 pin, and 6W florescent tube.
When I replaced the 2D bulb, only a faint light could be seen coming from it. I assumed because there had been some physical damage to the fitting, that a component inside was bad.
As I went to dismantle the unit (ready for replacement), I removed the starter module, and immediately the 2D bulb sprung into life. I put the starter back in, and the 2D bulb returned to almost lifeless. Took the starter out again, and on comes the 2D bulb.
Are these lights designed to not work if the starter is bad or if the florescent bulb is missing, or something else?
P.S. We don't need the emergency backup to work anymore, and I'm happy to leave as is. Just curious about why the 2D bulb works when the starter is removed.
Any clues on what was happening?
