Good evening,
I was wondering if anyone has seen SWA cleats that would comply with the 18th edition reg 521.10.202 (i.e. not liable to premature collapse etc...)?
The data sheet for cleats produced by SWAonline say they are 'stable' between -350c and 1050c but they are still made of plastic! Not sure that would be what I am looking for. All well and good using a metal plug and screw but surely the cleat with give up first?
Regards
Someone can correct me if I'm wrong but I highly doubt it that a firefighter will go into a building that is over 1050 deg C. I doubt their suits can that that temp.
Plastic is a bit of a Generic term.
Some plastics deform in warm water.
Some plastics have probably been to the Moon and back.
I'm reasonably convinced that SWA's quote about temps is either theoretical or a misprint, I'm not aware of anyone getting below -273c (absolute Zero)
Stability down to -35OC and up to 105OC constant
Maybe I'll tie it up with strips of fire fighters suits then.
Sadly I don't have time to write a list of the infinite amount of scenarios I would like to exclude from my question. But you have covered two there... It's not being installed under water or on a celestial body.
Ah the joys of Physics :)
London
SWA cleats complying to 18th edition?
AdamSmith86,
freddo,
TrueNAS JBOD Storage Server
