View the thread, titled "Moving to the uk" which is posted in Australia on Electricians Forums.
Hey guys
My partner and I will be moving to England in a few months for around a year or so. I'm a fully qualified electrician in Australia and I'm aware of the steps I need to take to become qualified in the UK. I was just wondering if I could get a job doing security cams or door access systems (extra low voltage) without doing all the 18th edition course etc. I'm only there for a short time and don't really see it being viable spending a few thousand pounds on courses and books if i can get a similar job in the same industry.
Thanks heaps
CCTV, alarm systems, access control, all no problem. without UK electrical qualifications you'd be limited to domestic work involving non-notifiable works, ( notifiable works refer to new circuits, replacing CUs, works in bathrooms or other special locations).
so no licence would be required for cctv etc?
we don't have licences here. anyone "competent" can carry out electrical works, subject to a thing called part p, which means that to comply with notifiable works, you need to join a competent persons scheme.( about £500/year fee) which would entail 18th ed. regs as a minimum .not worth the hassle and cost if you're only here for 12 months.
As mentioned above plus, Data cabling, and i guess you could sub contract to an electrical contractor that is signing off the work . Good luck and oh BTW the weather is crap here, bring warm clothes, waterproofs and a wooly hat..lol
I don’t think so mate. Proper built houses over there. Chasing brick, installing capping or conduits.... putting in Noggins for back boxes all takes time.
not much brick to chase in a UK new-build,.... all thermalite block with dot and dab board, or studded walls.
I thought it was a narrow margin between 20 and 22
20 or less, Tools down it too cold
22 and above, too hot best hit the beach for a tinny and bbq?
I know all there is to know about Australia, having watched crocodile Dundee several times.???
Reply to the thread, titled "Moving to the uk" which is posted in Australia on Electricians Forums.
