The 5 strings of 7 panels were a test run (perhaps overzealous) - I intend to return to my original set-up of 2 strings of 9 panels for one inverter, and 2 strings of 10 panels for the other inverter. (Each would be a little less than the 2*10A outlined in the user manual [would be 2*9.26A for each array]).
The cable running from my inverters to the pv arrays are already underground and thus limit access to the children and animals, and I have isolation switches at both the arrays and by the inverters.
I will buy the appropriate cabling for the batteries - however I have a question regarding the appropriate circuit breaker: does the example in the link below seem appropriate to you? (battery circuit breaker)
The inverter is placed in the garage (where it is much cooler than anywhere else in the house) despite the southern temperatures outside [I am in the South of France].
I have a question regarding the battery set-up: I am intending to have both my inverters put to use with the array set-up described above. Do I arrange 4 12V 200Ah batteries for each inverter, or do I arrange a total of 8 of those batteries with 2 strings of 4, connected to one inverter, which itself is connected by a second pair of battery cables to the other inverter (and having the inverters connected in "parallel" i.e. connected with the communication cables and set up in the SolarPower application in the "parallel" configuration)?
Hope that what I'm trying to communicate is clear to you - and again, thank-you for your help!
Would these batteries work for my set-up? They seem, at first sight, to fit the description.
Thank-you again!
