What you are doing is not safe. Either seek the services of an electrician or use a switch which does not require a neutral.
Are you picking up the neutral from the correct neutral bar?
As in #22 you probably have a dual rcd or split load consumer unit which will incorporate more than one neutral bar. You are probably picking the wrong one to connect to.
icture ONE
brown is permanent Live
Blue becomes live when the switch is ON
picture Three
Quite clearly this switch consumes energy to operate.
I have put the brown wire into the L in terminal of the new switch
I have put the blue wire into the L out terminal of the new switch
I have run a wire from picture TWO (3) to N in of new switch
This trips the fuse every time - what am I missing?
The neutral needs connecting direct to the rcbo of the appropriate circuit.
A qualified electrician is en route to complete the work. I have created a route for said Neutral and he will install, although he assures me he will do almost exactly as I would have done.
Almost exactly. But not 'exactly'.
manchester
No neutral smart switch, faulty?
Lighting Forum
inaminute23,
NickMoore1968,
