I suspect however they will ask you for a report in accordance with the Electrical Safety Standards in the Private Rented Sector as this is what they must obtain.
No it's notHi - as per Andyb, the forms I know of (and use) are the EICR from Appendix 6 of BS7678. Are there other forms or standards that we should now use for domestic rental properties?
Is the intent to require non safety related items to be C2 and therefore force them to be upgraded?
Undermines the whole a bit doesn’t it.....?Of course one of the most glaring errors in the S.I. is it does not apply to anyone but private LLs. That means that all of the charitable and social housing organisations are exempt from these requirements. Which I think is pretty pathetic.
What the legislation demands is irrelevant to the individual carrying out the test and inspection. This legislation is aimed at the landlord it is therefore up to them what extent of remedial works is required from the submitted EICR.Yes, I get your point, unfortunately I can see that lawyers and courts might interpret it in quite a different way, 'you were asked to provide a landlord's report in accordance with the legislation as a competent electrician'.
Whilst I agree that what should be done is an inspection in line with periodic inspections as defined in the current edition of the wiring regs (in Scotland, that's what is required under the equivalent legislation) the plain fact is that the English legislation has defined the requirements differently, basically demanding compliance with the current regs.
This opens it up for lawyers to argue for compliance as basically that's what the law states.
I wouldn't want to be the one defending the 'custom and practice', or 'that's what they really meant' against a fancy lawyer, as they may have a better lawyer than I can afford!
That’s exactly my way of thinking I conduct all my EICR’s to current regulations and any consumer units not meeting fire rated standards i deem as unsatisfactory although I know a lot of sparks class this as C3 I prefer to be more strict and don’t try to find ways around upgrading just upgrade the installation to satisfy current regs simple in my way of thinking. Although I do understand that financially it could be detrimental to the landlords but that’s what the rent payment is for maintenance and upkeep on your property.What the legislation demands is irrelevant to the individual carrying out the test and inspection. This legislation is aimed at the landlord it is therefore up to them what extent of remedial works is required from the submitted EICR.
Reply to the thread, titled "The new Landlords' EICR requirements. The law says that everything must now be to 18th Edition!" which is posted in Periodic Inspection Reporting & Certification on Electricians Forums.
