LastManOnline
Supporter
Metal CU.
Am curious to know why the UK regs demanded a metal CU. Would it not have been helpful to first investigate what was causing overheating the CU?
It's not just against regulations but it's actually against the law over here for a layperson to install a CU. In fact it is now against the law for a qualified electrician to take the cover off a CU in a domestic installation unless he is a registered contractor as well as been a conventionally trained electrician. A little OTT I know but that's where we are at the Mo.
Are you an REC.
Interesting - not sure that would go down well here :) Though I guess it would be consistent with Gas Regs. But pointless if it's not enforced anyway...
it is been strictly enforced here.My inspector (we currently get 1 inspection a year) has made a point in recent years of highlighting the number of people fined or jailed for contravening the law (previously known as "the regs").
Anyway here's a thought regarding my original question. There are many foreigners in my area with homes, some resident, some holiday. I notice that those most likely to carry out their own electricial work are from UK. I wondered could this be a factor in your issues with CU fires?.
[automerge]1601326578[/automerge]
Are you an REC.
Yes
I'm not sure there has been a massive increase in DIY activity for CUs to explain fire matters in recent years.
While you see a few pop up here asking for advice, I suspect the main issue for CU fires has been "professionals" who are useless at electrics. Not just the builders & plumbers who have a go and get berated here, but also a general de-skiling of the trade due to the loss of apprenticeships and the pressure to get qualifications in a few week's worth of a course.
While I am in favour of torque screwdrivers (on the same principle that I would always use a torque wrench for doing a cylinder head, etc) the recent increase in that aspect is probably also down to poorer skills/experience, and maybe poorer products with less tolerance to tightening effort, all down to the same issue.
That is certainly an interesting point about the de-skilling taking place in the trade. I was, nt aware of that. What was the general reaction to the introduction of the metal CU like among sparks in general.? After all, working with metal is usually more labour intensive than plastic
I think it is true that there are a lot of fires that are electrically started, but I also suspect the majority are not due to fixed building wiring but are defective appliances.
For example, it was a fridge-freezer that started the Genfell fire, the worst in UK recent history. But the main reasons that led to such a great loss of life was lax building standards and, to a some degree, various issues relating to fire-fighting. But usually it is things like tumble dryers that are more common fire hazards it seems.
I can't speak for others but I am in favor of metal CU, it just seems sensible to have something that is reasonably tough and fire-resistant even if the risk from a well-fitted CU is negligible. But as mentioned, a decent grade of plastic that meets fire containment and LSOF behavior would be fine as well.
Perhaps they don't trust industry and/or cheap imports to keep meeting a specific grade of plastic, but "is it metal?" is harder to dodge. Who knows?
Agree 100% on this point about the fixed wiring not been the origin of electrical fires. Statistics on this one not easy to come by. Secondly I would have no objection to installing metal CU, s in domestic installs providing there are sound and justifiable reasons for doing so. I struggle a little with the concept of having to adjust the materials because of poor installation skills on the part of untrained/semi trained personnel. I would prefer if the issue was approached from the direction of upskilling the personell
I don't think it's necessary because of them expecting poor workmanship. It's just an additional safety precaution in case someone does make a slip up nobody's prefect, although it may have been overly cautious.
What's that old saying "if you haven't done anything wrong you haven't done anything"
Wouldn’t it be nice if you could get consumer units made of glass or other transparent non flammable material?
Might force a bit more pride in some people’s work.
There have been a few installations posted on here that look so good it is almost a crime to cover them up!
Metal CU.
Question What are Junior and Senior Trades qualifications issued in IRELAND? out of interest
[automerge]1601391413[/automerge]
Seen a few that need covering up though
I assume you meant When they are issued? If nothing has changed since I came out of my time, than junior trades after 2 years and senior trades on year 4.Some sparks would then simultaneously do the C&G equivalent
Thanks Ed, but what exactly are the two Quals, Junior and senior what do they equate to? City and Guilds wise
[automerge]1601392593[/automerge]
OK but what are the CnG equivalent? not an unreasonable question I think.
Apologies. I don't believe the Junior trades has an equivalent in The UK. The Senior trades used to be equivalent to the C&G course B. That's how it was in my time. (For "my time" read "old fogies")
LastManOnline
Supporter
Ireland
Ireland
Business Name
Able Electrical
Metal CU. Why?
LastManOnline,
Mike Johnson,
