I am bringing this drawing back into the discussion just to ask one last question.
In the drawing there are twelve (12) buckets on the right side. Just for discussion each bucket has a lifting force of 100-foot pounds. 12 buckets times 100 = 1200-foot pounds of lifting force.
1200-foot pounds of lifting force can produce more energy at any one moment in time than 100-foot pounds;
Once all the buckets are full and this machine is running, the process continues to produce 1200-foot pounds of force if you continue to fill one (1) bucket at the bottom in sequence with the rest.
YES or NO?
how are you going to get the air into the inverted buckets at the bottom of the sea? electric compressor or the Airbag Fairy?
telectrix, I’m not sure how you knew this, but I did try to get The Walt Disney Company to grant me a license to use the name “Airbag Fairy”. If they agreed to grant me the license, I intended to include you in the agreement.
My contact was Jennifer Fredmen
Licensee Requirements | Disney Licensing
Disney turned me down, but had they agreed I was going to share the proceeds with you.
bubble in seawater rises around 220 mds and almost same as that in artificial seawater and distilled water
MT03014FU.pdf (witpress.com)
Speed of rising bubble
220 mds
1 inch = 25.4 millimeters
220mm = 8.66142 inches
12/8.66= 1.3854 feet per second
33/1.385= 45.7182 seconds
Between refiles is therefore every 45 sec+/-
Is that even close?
I’m still waiting for someone to check the math but that may be a stretch for an electrician to compute.
I hope no one gets shocked---No offence intended or implied.
Back to the OP
My calculations of the speed of the rising buckets did not consider the drag caused by the generators attached to the circulating cable.
The reason I ask this is because this will determine how often a recharged air tank would have to be recharged.
Any suggestions?
I just saw the warning below---
Now I understand why no one or only a few cares to participate in the discussion.
IMPORTANT: Please note that nobody on this forum should be seeking from or providing advice to those who are not competent and / or trained and qualified in their field (local laws permitting).
I admit it, I am one very old (71 years) incompetent old man that suffers from daydreaming. My doctor has advised me to spend my time on an internet talk board where I can daydream ideas in/on a safe place instead of daydreaming while walking near or across public streets.
Please, just ignore me & just let me talk to myself until I follow asleep, hopefully for the last time
OK
OK
I think a bit of day dreaming does us all good !
texas
United States of America
Other
If other, please explain
interested in the future of humanity
A new energy source-maybe--maybe-not
USA Electrical Forum
Tags Tags
energy new
justcurioustwo,
SparkyChick,
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
