View the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
Darkwood
I've installed screened PVC trunking before, the data compartment was coated with copper. Super expensive.
Yes and obviously u can get screened data cable too
The advice given to me though was not to use it unless specifically requested, dunno how accurate that is
I used to do just 1st fixes back to comms cabinets and basic laying of cabling
I see a lot.of contractors when they scale up they suddenly become an engineering firm not to mention dropping the first name
So they start off as "Mikey Smith Electrical "
And then they change up to "Smith Engineering"
To be honest it's nice to see people not just using the 'First three initials + electric(al)' formula. I bet there's about 2000 'JBL Electrical's in the UK.
The story behind this. It’s a sub main from the main CU in a empty rental property.
I’m not quite sure but I think this is known as the “F*ck it, I’ll use the Australia method as I don’t know what I’m doing’!
I’m actually impressed someone could mess it up that bad. ?
Surprised everything still operates. Is that some chewing gum they've left on the misplaced bus bar?
Im guessing that the power coming in is via the furthest right hand side breaker...
That is a special kind of badgers arse consumer unit , that is so bad its actually quite funny
Correct
It is fed from a 32a MCB in the main CU but this is where the right way of doing it stops.
Live is then fed to the far right 32a MCB in this board, with a link back to the RCD, the neutral is direct to the RCD. And every circuit is fed upside down.
Impressive to get it that wrong. ?
I did think that when I first opened it up.
It’s a bit of mortar that’s dropped in the excessive opening at the top.
Aside from that is directly exposed, looks like a snake mating ball and needs to be in a wiring centre.
They have cut the earth from the stop cock (just inside the wall to the right) so there is now no earth to any of the pipes in the property. They choc-bloc it into the heating system to give that an earth (I think the plumber might have had a go here). I tested all the pipes I could read with my wander lead and none got anywhere near the 0.05ohm allowance. Lowest I got was 13.6
But at least they cut the earth off the metal sink/drainer as it wouldn’t have worked anyway. ?
Reply to the thread, titled "Dodgy trade pictures for your amusement! - 1 Million Views!" which is posted in UK Electrical Forum on Electricians Forums.
