Identify heating controller
littlespark
Staff member
Supporter
Patron
Morning all.
I’m sure all you human beings will be quicker and more accurate than google…
Can anyone identify this heating controller.
Looks like it’s missing a flap on the bottom…
You need to get someone whos competent to have a look at it.
I would disconnect the timer and ensure that the valves/boiler etc are all working as they should before actually changing it.
Hi, thanks for response, They are a competent crew and do our setvices on boiler and gas fires, but my only query was the option to use the honeywrll T4r as the replacement, as that option hadnt appeared in my searches !
The tr4 is a wireless programmable thermostat
It won't control the hot water side of things as your old one does.
This would be better
The Randall controller we have has a separate wired thermostat, that to be fair is in the wrong place as it is in an upstairs room that i use as an office/workspace and never have the radiator on, thus the thermistat is at best, inefficient 😉
One of these would do what you want.
Especially if you want to put the room stat in a different place to the controller.
littlespark,
mainline,
