arifpatelprestondubai Dec 15, 2022 #1 Hello Folks Myself Arif Patel Preston Dubai, I Wanted To Know Which Type Of Wires Uses In AC's At Offices? If You Know Please Reply Thank You!
Spoon - Mentor Arms Dec 15, 2022 #2 arifpatelprestondubai said: Hello Folks Myself Arif Patel Preston Dubai, I Wanted To Know Which Type Of Wires Uses In AC's At Offices? If You Know Please Reply Thank You! Click to expand... Are you asking what cables should be used for Air Conditioning Units?
arifpatelprestondubai Dec 15, 2022 #3 Spoon said: Are you asking what cables should be used for Air Conditioning Units? Click to expand... Yes! AC Power Wire Uses In Uses In Commercial Pupose Like offices, factories, school, colleges etc....
Spoon - Mentor Arms Dec 15, 2022 #4 arifpatelprestondubai said: Yes! AC Power Wire Uses In Uses In Commercial Pupose Like offices, factories, school, colleges etc.... Click to expand... I would go with: All depends on the install. Where the unit is mounted, environment, risk of damage to the cable.
arifpatelprestondubai Dec 15, 2022 #5 Spoon said: I would go with: All depends on the install. Where the unit is mounted, environment, risk of damage to the cable. Click to expand... Obviously In Commercial Area High Risk Of damage..
Spoon - Mentor Arms Dec 15, 2022 #6 arifpatelprestondubai said: Obviously In Commercial Area High Risk Of damage.. Click to expand... Ok, so if there is a high risk of damage and the cable isn't going in metal trunking or conduit, what cable is suitable for that environment?
