Currently reading:
DIY - replacing manual shutter roller wall switch with smart one
Discuss DIY - replacing manual shutter roller wall switch with smart one in the DIY Electrical Advice area at ElectriciansForums.net
Kallo444
Hi Everyone, DIY advise required here please.
I have the following wall switch, currently wired in as below and controlling external roller blinds.
Inside the wall view has additional wires.
My DIY project is to replace the wall switch with a smart one below
And here is my wiring diagram
After switching ON the main fuse, the smart switch power ON for a second and another fuse tripped.
Do you see anything incorrect with my diagram or it was perhaps loose connection that tripped the fuse?
Many thanks in advance for looking into this!
How have you verified that blue is actually a neutral.
What actually tripped an mcb or rcbo.
That is just a circuit breaker. So the one that trips is not the circuit for the shutter?
Reply to DIY - replacing manual shutter roller wall switch with smart one in the DIY Electrical Advice area at ElectriciansForums.net
