I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps tripping with no switches or even bulbs being attached to the circuit. Even trips when other appliances that are not on that lighting circuit are not being turned on or off.
The fusebox was replaced 2 years ago with RCBOs. The wiring is old however a condition report was issued as a pass at the time the fusebox was replaced. The ground floor and upstairs lighting are on a single 6A RCBO with borrowed neutral, this has worked fine until now.
During a insulation resistance test there is a low reading on the ground floor lighting however still a pass.
The electrician and I did the following scenario/tests:
Could the ground floor lighting wiring insulation have become damaged/degraded?
Thank You in advanced.
- Replaced lighting 6A RCBO - RCBO trips randomly within minutes or few hours
- No bulbs attached and no light switches pressed - RCBO trips randomly within minutes or few hours
- Bulbs attached no light switches pressed - RCBO trips randomly within minutes or few hours
