No, no such thing exists.
If you only need 1 way switching then you could use a double pole switch.
If it needs to be 2 way and a standard plate switch then you coulse a 1 gang switch to operate a relay.
We like crazy!Food for thought. As for what I'm doing its a bit crazy so don't intend embarrassing myself here.
I did wonder about a fan isolator but thought the 2 way element of the question ruled it out - interesting if there is a 2 way version out there, I need to find that now!Some fan isolators come as two way for some reason… I’m sure I’ve fitted one.
So you get 3 gang 2way, switching symultaneously
Physically a wider rocker, but will do as you need.
That last idea is ingenious and I might well try it out.
I think what I'm doing is ok from an electrical standpoint (and indeed allowed I think for a DIYer like me) although I suspect tinkering with manufacters products is probably not allowed by the wiring regs but lets park that for now.....
However, its definitely not allowed from a gassafe point of view. I'd be ok to share if I don't get shouted at for GS related issues....(i.e. a DIYer shouldn't be doing any gas/boiler work whatsoever)
Thanks a lot by the way for the discussion so far - very interesting.
Reply to the thread, titled "2 gang 2 way switch with a single rocker" which is posted in UK Electrical Forum on Electricians Forums.
