timhoward
Broke Internet
Supporter
I have a customer that had an older street light with a 30W Phillips Sox bulb in in. It's an absolute pain to get to as it's mounted on a building very high with obstacles preventing easy ladder access and steps / ramps at ground level all around it.
When it stopped working I offered a new LED unit. He would rather keep the 30W Sox bulb as he is suspicious that either converting to LED bulb or a new LED unit will mean needing to access it more frequently due to lesser reliability. He asked can it be repaired, which is a question I never mind considering.
The actual problem is not the bulb which is still available, but with the Phillips EXC 055 S/50 electronic ballast unit (which itself was retrofitted at some point) and seems to not be available any longer. I wondered if any of you fine lot is aware of any alternative products that will do the job? Were low pressure sodium bulbs an entirely Phillips thing?
The only units on ebay have are conventional ballast and ignitor units and we are not going back there! It may be that it's the end of the road for this style of lighting and he will need to accept that!
I can see his point that the current setup has lasted about 12 years without being touched, and I don't feel like promising an LED replacement will do the same.
Thanks for any thoughts.
They’ve all been nicked to start weed grow rooms…..or so I’ve heard.
Ah, that explains the scarcity of them!
It's looking like he has a choice between
1: something 2nd hand like this: PHILIPS 35W SOX STREET LIGHT LANTERN WITH NEW LAMP, HAS PHOTOCELL AND GEAR 240V | eBay - https://www.ebay.co.uk/itm/326317128377 if he REALLY wants to stick to this technology.
2: converting the fitting to an LED corn bulb
3: a modern LED street light.
I think I'll just tell him no warranty with option 1 or 2, manufacturers warranty (often 5 years) with option 3. His choice!
where are you based?
i may have one or two in the garage.
timhoward
Broke Internet
Supporter
Oswestry
Ballast for low pressure sodium street light bulbs
timhoward,
timhoward,
