Guest viewing is limited
View the thread, titled "Automotive (bike lights wiring circuit)" which is posted in Auto Electrician Forum on Electricians Forums.
So, I am a relative beginner (only fiddle when needed and usually following clear instructions or diagrams) when it comes to 12v switches and relays, but I am needing some help with a set of switches and a micro relay I purchased from Amazon (those who purchase here know most stuff comes with either no instructions or very basic and unclear sets). The switches are 5 pin latching on/off with an led halo light and come prewired with three wires and, as stated, the relays are micro 4-pin 12v 30A SPST labeled with pins 1,2,3 and 5. I am assuming that the relay, though numbered different, is essentially the same and that pin 1 = 86 (+), Pin 2 = 85 (-), Pin 3 = 30 (+), and Pin 5 = 87 (+ to device when closed).
Now for the specifics:
Yellow wire of the switch is soldered to Common (which I assume would go directly to positive of the device.
Red wire of the switch is soldered to both NC & "+" (kind of bent and bridged, so I assume this means that the halo would illuminate when the button is pushed and in the ON position). For the one I want to be able to control accessories allowed to operate despite key position, this wire would go to battery positive, essentially giving it power at any time it is in the latched ON position (yes, I understand this would allow a vampiric draw if I failed to switch it off) and for the ones that are only powered when the key is on, this would be wired to the relay's pin 5 [87] while the relays pin 3 [30] would be wired to battery positive and relay pin 1 [86] to the keyed ACC.
Black wire of the switch is soldered to "-" which I assume is basically wired to ground for the sake of the led being able to illuminate.
Here comes the kicker part, and my absolute confusion: One of the items I want to leave to be able to operate at any time is a set of bluetooth LEDs that come prewired with a switch in the ground wire. This switch is actually very inconvenient as it would be under the seat since that is where the controller is placed. I am assuming I would need to rewire the one LED switch so that the NC and + are separated and that the Common and NC would complete a ground circuit when the button is pushed and in the ON position. I could bridge Common and "-" of the switch and run the Yellow wire to the switches NC pin and the other end to the ground of the controller. Red switch wire would essentially just be powering the LED of the switch.
Are my assumptions correct, or am I making a total A$$ of myself (lol)? If I am not correct, would you mind giving me a better understanding?
I am baffled after reading that lol
Is the halo the only thing being powered here?
Dan,
The switches each have a led halo that i want on when the device is on. There are three switches total to be mounted on a motorcycle; one will power the Bluetooth led strips (which will have constant power with the switch wired to complete a ground circuit as I stated), the second will power my driving lights, and the third will power the fog lights. These last two will be attached to the micro relay as stated, so will only be powered when the motorcycle is running
I see I think that extra info will help. I'm not an electrician myself I just make the tea here. :)
I am always messing with additional lights on my cars. Usually switching rear bulbed units for LED versions (usually blacked out when turned off). If I was with you and the bike I'd get them going but probably not technically correct. I love it ha
But I think you'd probably be able wing it too but you're asking the proper way.
Something I'd not even be able to do. Ha
Good luck matey. Show us a picture of the bike!
No*
-Could you hardwire the ground wire and make your button the switch on the positive side?
-If its a physical button that stays pressed or a physical switch you can still switch the positive side, and have switches on both sides, annoying but at least you wont just have a pointless button.
Button wiring to send negative switch to the device if for some reason it absolutely cant switch on the positive side.
Yellow / Common - negative
NO/ Normally Open- Device to supply power too.
NC is normally closed - its default before its pushed.
As they stand, pushing the button will turn off the light and send Positive to the NO.
+/ Positive and negative aren't switches or supplies, they're just for the light.
Im not a great explainer and I'm a first year apprentice but here's a diagram I found online for changing the light based on the buttons toggle.
My best description for the button:
+ Positive - Is for the LED light, when the light should turn on
- Negative - Also for the LED light, But its earth side,
NO - Normally Open - The button will complete this circuit when pushed.
NC - Normally Closed - Default before the buttons pushed, it will switch off this supply when the buttons pushed.
Common - The supply to NO/NC.
If I can help any more let me know,
Please add fuses.
Reply to the thread, titled "Automotive (bike lights wiring circuit)" which is posted in Auto Electrician Forum on Electricians Forums.
