Converting 2 gang 1 way and 1 gang 1 way switches to 3 gang 2 way
I need to covert 2 gang 1 way and 1 gang 1 way switches to 3 gang 2 way. Switches needs to stay where they are but I can run cables between them. Is anything wrong with doing it as seen in the picture below? I did not include earth cable but both boxes are grounded.
For a pointer…. Every connection should have at least one cable in it.
Are the lives at each switch position on the same circuit?
It can be done by running only 3 x twin and earth cables between the switches.
At the moment switch 1(2 gang) is fed by 3+E and switch 2 (1 gang) is fed by T+E. All lights are in the same circuit
Hmm. No
I’m trying not to fall foul of the “no step by step instructions” forum rules…. But it’s really difficult without just telling you how to do it.
Would it help by explaining how a two way switch operates?
It’s merely a changeover switch. Rather than on/off it switches between L1 and L2
For a simple one gang switch at each location…
A live feed into the Common of one switch, a pair of cables linking L1 and L2 at one switch to L1 and L2 at the other switch, then the switched live going to the light from the Common of the second switch.
Now apply that explanation into your scenario.
To be fair to the OP, it looks as if the style of two way switching is intended to be as below.
If all lights involved are indeed on the same circuit, what's been drawn in post #1 is not incorrect, but it is incomplete.
A link has been missed on the left 3 gang, and two links missed on the right 3 gang.
Maybe I'm misunderstanding what's meant in post #6, but that mention of interconnecting L2's (just at each gang, not between locations) is essentially what's missing!
The subsequent wiring between the two locations could surely be done either by 3 off T&E, or by 2 off 3-core & E, but colours wouldn't be quite as illustrated in post 1
The way I was thinking, avo, was that the live and switchwires are at different switches.
Then it’s just the new twins inbetween being used as the strappers.
I was just thinking all L2's can be supplied with Live without running anything between locations.
You are just left with 3 x com and 3 x L1 to run.
Maybe that suggestion doesn't help!
Hmm. No
Thanks but I am afraid I am unable to do it this way as I cannot rewire cables in walls. Live and switched live cables have to stay where they are (switch 1 for light 1 and 2, switch w for light 3), so I am essentially trying to add a second switch to each of existing gangs
Thanks, I think you are bang on what `I am trying to achieve. I missed interconnecting L2's in my original post. I have corrected that now. Is below drawing ok?
There is a permanent live to connect to L2 of all switches already in place, so you will need three strappers to connect the 'coms' of all three switches to the 'coms' of the other three switches and three wires to connect the L1s of the three of the switches that are not near the feed to the light they control to the L1s of the other three switches that are.
Six wires in total between switch positions.
Do you mean just bridging all 3 L2's in switch 1 from 3+E and all 3 L2's in switch 2 from t+e and then just interconnect L1's and coms between 2 switches using 2 x 3 core cable instead of 3?
Luka,
Luka,
