Problems with phone sockets and wi fi.
Hi. Pulling my hair out with this one. I'll try and keep it simple. Recently I've moved into a new house which has eleven telephone points dotted around in different rooms. They are wired from the master via two radial circuits, one serving each side of the house. The wiring appears to be a mix of ordinary telephone cable and cat 5 cable. All seems punched and connected correctly. That's the background to the installation. My problem started when we tried to get broadband. It was very slow so after disconnecting all the internal wiring and trying again this didn't improve. So problem externally there then. But what broadband I could get was knocked off unless I disconnected my cordless phone. Why is this? The wifi does not agree with the cordless phone. Another problem- the last two telephone points on one of the extensions don't work when I plug the phone in. Now I've tested the cable and belled out each core and disconnected and reconnected the terms but no difference. This one really has me going. Also my phone gives a two tone almost like a police siren on the dialling tone- maybe because it's not getting enough power externally? I know this all sounds confusing but maybe someone will understand.
Depends on the type of master socket you have. If you don't have a master socket that splits the incoming line between phone and adsl then EVERY connected phone will need to be connected via a line filter.
Yeah mate I know about the filter. I have an ordinary corded phone and a cordless phone with a filter on both. Corded phone works fine with wifi. Cordless phone knocks it off. My master socket is one of those from bt which has two parts. When you take the front off this disengages the internally wired phones.
That includes any other phone line connected non adsl device, ie SKY box, don't shoot me ... just checking :)
Mmm not sure mate. Her indoors set it up. I take it if it was set up for one channel your maybe thinking that this is clashing with the frequency of the cordless phone? Where as if it was hopping it would maybe find a free channel?
Yes, and it's not just the cordless phone that may be interfeing as well. Any other devices on 2.4Ghz may also cause a problem (including wireless doorbells, TV RF senders and the neighbouring wireless equipment).
You can normally check in the config pannel for the wireless settings on the router. It should be set to auto and not a specific channel.
Ok mate thanks I'll check. It's a brand new router from sky so would imagine it would let me configure. Any idea why two sockets won't work even though all wiring and connections are correct?
Is there a possibilty, given that some of it is in cat5, that a twisted pair hasn't been used and it's disparate cores. Failing that maybe be a poor idc connection, enough to get continuity (typically <2Ohms or so) but too high resistance for a signal.
Thinking about it, in this case you don't have an adsl signal to worry about; so not using pairs wouldn't matter too much, it's just a telephone extension to all intents and purposes.
hoover,
hoover,
