Mark.W
Most of the questions from tonights exam (from memory) are on this thread:
http://www.electriciansforums.net/e...-301-written-course-aftermath.html#post386202
Can't seem to open it mate!
But if you test R1 + R2 you link L-cpc at board and test btw l- cpc on other side, the bonding doesn't come into it!
But surely parallel earth paths won't play a factor because you have disconnected your cpc at db in order to link it to line! All you are testing is the cpc and line conductors!!
Why do you think SELV has anything to do with it?
There was no Insulation testing, so SELV does not matter, it is put there to confuse you. You only need to read the relevant parts that you need.
It also said it was a 4 bedroom house. You dont need to know that, it is random details thrown in, and you need to pick out what the question is asking.
*So, RCD test on lighting circuit, which includes SELV lights. Are the SELV lights relevant for a RCD test? No, so ignore it, and do a RCD test. Think, is it safe to connect your probes to a light fitting? Probably not, so you would do the test at the RCD. Ensure all loads are off, then test as you would normally test an RCD, but instead of being at a plug socket outlet, it is at the DB, so you have to state the precautions required.
*It was 15 easy marks for that, if you read the question, and state all steps to obtain the RCD test results.
*If, hiwever, like me, you forget to do the 180 degrees tests, you lose 3 easy marks just like that.
