upstairs & down stairs????or Not!!
S
Smilers
Hi all just wondered if anybody else had seen this before? Ok i carried out a test on a domestic property only to find that the two Ring FC's had been wired so that one circuit was the front of the house both upstairs and downstairs and the 2nd circuit was the rear of the house approx 6-8 sockets on each RFC. I have seen before the landing socket being wired into the downstairs ring and vice versa for obvious reasons, but not front and back. The house is mid 80's build it has not had any extensions so the obvious is not a possibility. Cheers Gents:smile5:
Seen all sorts of ways of wiring lighting and and ring main circuits. I always try to mix them up a bit if i can, front and back or left and right. if the cooker switch has a socket on it i put it on the opposite RCD to the downstairs ring so that should the downstairs ring fail, they have at least one socket that will work etc. So long as the CU labelling reflects what circuit is powered by what, it's good to let the customer have options should there be a failure, ie if the dining room lights fail, the living room lights will still be available....
A house i once lived in had had a extension which was a kitchen, when we redone the kitchen i was changing the sockets and went to the CU and pulled the fuse marked Kitchen..walked in flicked on the kettle nothing happened, so all good.
I was changing the sockets on one side of the room , my dad on the other all of sudden *BANG* and some swearing from my old man..turns out half of the kitchen was on that fuse and the other half of the kitchen was on the downstairs ring. From that moment i have always checked every point. He didnt half mess up my pliers.
when you go to most house there is no information of this, charts etc...... when making up one of these parts to you have to check all sockets and where thwey are comming from, seems very time consuming??? anyone
or would you just turn on fuse/mcb then plug in your socket tester??
Just shows how not carrying out the correct procedure for an isolation can prove dangerous.
yet i'll bet there's nobody on here ain't got a pair of cutters/pliers without skid marks to match his underpants.
Steinels mate....everyware..everytime.......
i wa told that was how houses were rewired in the old days, in 2 halves ,up and down front up and down back . so you would still have electric on each floor if the fuse blew
Yep when the 2nd ammendment comes out in a couple of years this is probably what they will come up with lol
In the old days,folks were lucky to get a socket on the landing and one each in the lounge and kitchen,singles as well
Even luckier if they had something they could plug into them
And a generation or two later, look where we are: multiple radials and rings, lights up and down, dedicated safety circuits, choices of protection, sockets everywhere......and still naff all on the telly when you plug it in!
Currently doing a kitchen extension....10 appliance radials....2 rings...2 sockets radials...3 lighting circuits..smokes....just in the kitchen....Whatever happened to a couple of sockets,cooker and a 5ft flu on the ceiling?:ninja:
Smilers,
PC Electrics,
