View the thread, titled "example questions wanted!" which is posted in Australia on Electricians Forums.
S
ste_miller21
hello, ive got my 1st part p assessment with Elecsa a week on friday. ive got everything in place. i was hopeing that you fun loving guys could help me out at this point. im losing interest in my revision (dont seem to do it well).
COULD YOU PLEASE POST RANDOM QUESTIONS ON HERE THAT ARE THE SORT OF QUESTIONS LIKELY TO BE ASKED SO I CAN PRACTICE LOOKING THEM UP OR TEST MY MEMORY.
PLEASE AND THANK YOU.
Do you have any biscuits?
Now come on Davey,if the elecsa guy has to ask that question he's a certainty to fail,
He should stick with Do you like tea or coffee with your biscuits
Keep it on topic please chaps.
"What are the requirements with regard to Part L on a rewire?"
"What are the maximum operating time be on a 30ma rcd tested at x5?"
The latter you should be able to answer on the spot.
Ok, OK. Wel Napit were interested in...
Correct isolation
Switching in line
How many tests for an rcd? (Dont forget funtional)
Max ZS for 32a B 60898
IP codes and zones
... and other stuff about fountains that I had to look up!
What if the maximum EFLI specified by DNO's for the different earthing systems?
What parts of the building regulations do you need to consider when installing a new lighting circuit?
How long do you have to keep copies of installation certificates?
do you mean max ZE?
TNCS 0.35 OHMES
TNS 0.8 OHMES
TT 21 OHMES
to consider building regs: DOCUMENTS L1:
are certs to be kept for 6years (same as the warranty is valid for?)
RCD TESTS: two half cycle tests at 0.5 the RCD's operating current
two half cycle tests at RCD's operation current
two half cycle tests at 5times RCD's operating current
1.44 ohms
PART L: energy efficiency
max RCD time 200 MS
1.44 ohms
and rcd functional test! so RCD is tested 7times
Reply to the thread, titled "example questions wanted!" which is posted in Australia on Electricians Forums.
