P
Piratepete
Hi Guys
I fit a lot of IPX5 and IPX6 accessories and wonder if I should be drilling a drain hole at the spot that's usually indicated. Most have instructions that have no guidance except to say that the IP rating will be compromised if you drill a drain hole.
However the instructions with a make (rated IP55) new to me say that a drain hole is required if cables are glanded from the top or side and also if the bottom entry gland completely seals!
The question has added urgency since opening an IP66 adaptable box I installed some years ago (with side entry) and finding it half full of water! I 've always doubted whether the standard compression glands seal on flat cable. The downside for drain holes is they let the wee beasties in.
What do you do? Is there guidance anywhere on this? Started putting a blob of silicon at the gland entry now!
Cheers
Pete
PS. Whats a good way to fit a weatherproof double socket to a vertical steel column without drilling it? Any suitable clips around?
We always drill a small drain hole in bottom of any any external connection enclosure even floodlights as seen them fill with water so many times.
The factory seals on most enclosures do not seem to be up to the required standard.
Never had call back to connections after drilling a drain hole.
I would drill a drain hole. Weatherproof fittings make great water tanks. Keeps things cool until it goes bang. A bit of ventilation stops condensation as well.
As to the socket what are you trying to avoid drilling, the socket back or the column?
Drilling a drainage hole in high IP rated enclosures, is for condensation purposes, not for compensating for badly sealed glanding. Holes are drilled when these totally sealed enclosures are mounted/located in positions that will be subject to the occurance of condensation forming on the interior of these enclosures. In most circumstances this shouldn't de-rate the enclosure in real terms, as the usually 3.5 or 4mm hole is located at the back edge at the bottom of the enclosure....
Where I am if you drill drain hole it will be full of insects in no time. This often causes more problems than water ingress. I would rather use the correct gland for the cable and one of the same IP rating as the enclosure it's going into. You do get glands specifically for flat profile cables. Also only gland underneath the enclosure.
Hi Marvo
Wee beasties does bother me, though I haven't so far come across a problem with them
Glands for flat cables - where from? Bottom only entry. I agree, but life doesn't always let us - often have 3 cables exiting.
I think Tony and Micknew, above, have hit on the big problem - the accessories don't seal the way that they're meant to - this includes well known makes as well as the more obscure and cheap n cheerful.
Pete
It does seem to be a daft thing to do...drill a hole in 'watertight' box. Trouble is (I think) water vapour can sneak in through the tiniest of gaps, condenses inside & then the water can't get out!
As pretty much already said, I drill a drain hole to give any water a way out rather than keep it locked in. 3-4MM should keep them bugs out around here.
Should add, I used to work a little bit in food factories, and with there chillers keeping the food storage areas cool used to find an office area stuck beside it all the fittings and conduit just filled with water through condensation in no time at all.
Was chatting to my wholesaler this very week about this very thing as he had asked his sparks to put a drain hole, bit he hadn't done it. A few seasons later his kitchen ring (where it was spurred from) was tripping because it was letting water in via a badly fitted ip68 connection.
Certainly made me think. I doubt everyone does it, but it makes sense. However, i recon the wee beasties would get into a 3mm hole no problem.
Sent from my Samsung Galaxy S II via Tapatalk
Personally I will always drill a small drainhole in the bottom corner of the IP enclosure if I fit it outside or in damp environment. The exception would be if the IP rated box is of high quality or if it likely to be sprayed or jetwashed.
Worked in another safety critical industry previously, where keeping moisture out proved to be very difficult. If you get temperature changes then natural condensation will build up inside enclosures which screws up electronics. Most reliable solution is to completely fill with good quality potting compound or sealing it with a vacuum - not really practical for the applications being discussed!
Stick with small drain holes and keep your fingers crossed that the little critters don't make their nest in there!!!!!
Drain holes in Weatherproof Accessories?
Australia
Piratepete,
Engineer54,
