Personally i cant see a problem, however, i do see it as good practice to use 2.5 for socket outlets.
So is it better pratice to use 4mm and even better practice to use 6mm?
hi pevvers,Well if you're referring to the nice pictures in appendix 15 at the back of the BRB, you'll see a nice note at the bottom saying that these cables sizes refer to BS6004 "flat twin & earth" cable...
I want to know if its acceptable to run a radial to 2 x outdoor sockets using 1.5mm SWA on a 16a mcb
the original question was acceptable or bad practice, i answered acceptable but not good practice, there is a differenceOh I know that, but unfortunately that's the only form I possess...
But I think that the argument stands, if the original question is about a radial circuit, which with a 2.5mm twin would have overcurrent protection rated at 20A max, then if more wanted to be added then the overcurrent protection would have to be upgraded as well, along with the cable.
Of course, 2.5mm 90 degree armoured clipped direct could take more, but what crazy person would put a 2.5 on a 32A,![]()
