I carried out an EICR recently on a HMO. This raised a number of non conformances. The customer was issued with the EICR along with a quote to correct all the issues listed on the EICR.
They've now had the remedial work carried out by another spark who's not registered with any of the governing bodys.
I normally issue a MWC or EIC and a covering letter when i carry out the remedials, but in this instance the spark carrying out the work is not registered so cannot issue certs.
Am i correct in telling them i need to carry out another EICR?
Thanks for your help
The guy who carried out the remedial work should have issued a cert for this work, provided it warranted a cert that is.
What was the nature and scope of the remedial work ?
By the way, don't call the schemes governing bodies, it doesn't sit well on this forum.
Thanks for the fast response, i haven't got the EICR to hand, but one of the points was a break in the ring. The other chap has now split the ring into 2 circuits on 20A breakers.
You dont have to be registered with a scam to issue MWC's or any other certs. If the HMO is classed as a dwelling then some of the work he did may need notifying. If its not a dwelling then it doesnt fall under the part pee scope.
Jay
You don't need to retest the joint after the repairs.
I wouldn't notify the work to bring the place to standard either.
I would inform the customer that without evidence of testing and certification for remedial work, you cannot proceed in issuing a satisfactory EICR without extra testing at extra cost.
I've said that I need to carry out another eicr as I do not know if all the remedial work has been carried out. I just wanted to be clear about this as I don't want to look like I'm creating work for the sake of it. Thanks for all the replies.
Customers need to understand that work gets created when they penny pinch and opt for Dave from the pub to do their work.
I would give the customer the opportunity to contact the other guy and request certs for the work done. You should also inform the customer of any remedials done that should have been notified to building control.
lets just cut the crap , you did inspection , someone else did remedials , end of story.
move on , no point stirring up alot of aggro when you've probably no idea that the other guy didnt issue certs or a covering letter to accompany your eicr.
As Biff says, you've issued an unsatisfactory EICR highlighting all non-compliances, your remit is fulfilled. The onus is now on the person ordering the EICR to act on it. Whether they get you or someone else to carry out remedial works is up to them to ensure any works is certified accordingly.
If the s**t hits the fan it's now their --- in the line of fire, not yours!
JMO
Why would they want another Eicr,they have had the remedials carried out,there should have been certificates to go with the work
The certificates could then be used in conjunction with the Eicr for whatever purpose they be needed
If they had no certs and want another Eicr,crack on.its work that would have been un necessary,but hey that's their problem
Thanks for all the replies, so the customer could just get the spark (not a member of any schemes) to issue them with a covering letter stating that he has carried out all the remedials?
EICR Retest
nellyp,
Des 56,
TrueNAS JBOD Storage Server
