S
scott_free
Hello,
I am a musician with a home studio. I recently finished building a custom computer for recording. The new computer uses the same sound card and is plugged into the same wall outlet as before, but now I am getting disk access noise, mouse movement noise through my speakers.
I tied using my old PSU, disconnecting everything that was not necessary to run, but the noise remained. I then tried a ground lift and bingo, the noise disappeared.
Is it safe to use a ground lift when it is plugged into a grounded powerstrip?
scott
I realize this is probably a dumb question...but I do not know anything about electricity. The groundlift I am using is just a 3plug to 2plug adapte.
Ultimately, I know I need to locate the root of the problem inside the computer...I have two ideas to try, but it will be time consuming and take away from making tunes.
scott
