Multimeter | on ElectriciansForums
Guest viewing is limited
Discuss Multimeter in the UK Electrical Forum area at ElectriciansForums.net
O
OhmElectrical
Gents starting a new job after Xmas and need to buy myself a multi meter.
I will be doing routine maintenance in production line type stuff.
Anyone recommend a good make a model of multimeter in the past u have used what companies had but think I need bring my own to new job.
Used Fluke's for many years I have a Fluke 27 that's about 30 years old and still in use and a few years ago I bought a Fluke 289 and the Flukeview software and lead which is a good tool for those obscure faults, so my recommendation would be buy a Fluke
Have you considered getting a cheap (£10) one first, just to get going, then get better one after finding out what 'special' functions are going to be most useful?
Congratulations and good luck in the new Job.
The one I carry in my toolcase and use for almost every job I do is a dual display clamp meter which is basically a multimeter with AC/DC volts, ohms etc plus obviously an RMS ammeter. It's compact and it's particularly useful to be able to see current and voltage simultaneously when checking general circuits and motors/pumps/compressors etc.
[ElectriciansForums.net] Multimeter
If you're looking for something budget try Uni-t or Di log or Metrel.
Hi,
I would suggest avoiding the £10 ones, the big issue is what happens when you make a mistake and plug in the ammeter shunt and go phase-phase or phase N on an industrial 400V 3 phase supply. An expensive DVM will have decent fuses, the worst will be a small flash, loud pop and brown trousers. Cheap DVMs often have glass fuses and other issues, and in the above incident could explode....
What industry are you in?
Agree with Meterman - don't buy a £10 cheapy. Build quality and safety is atrocious. can't go wrong with Fluke, although may be worth buying a second hand one as thery do tend to be a bit on the expensive side. Daz
I find the Fluke range pretty good for industrial use, currently use a 175.
i got a 179 cheap on ebay for £112 inc vat+ delivery on ebay
you can get cheaper and a 175 etc would probably be fine.
i really like it but i only got it because it was cheap on the auction.
before you decide which fluke to go for have a think.
you want usa made because if you buy them new they have a lifetimd guarantee (10 years on lcd)
this alone will pay for itself
Reply to Multimeter in the UK Electrical Forum area at ElectriciansForums.net
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
Obviously not a building/DIY forum so will keep it short but yes - we've taken all the floors up. Several joists in the bathroom need doing as...
Recommended Sponsor News
Hi everyone,
