Using tp&n isolators | Page 4 | on ElectriciansForums
Discuss Using tp&n isolators in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Re: Using tp&n isolators
Wow the 7th of april 2012!!! How the hell did you even faintly recall that post?!?! Last week is now a struggle for my frazzled head!
Strange as it may seem I recall seeing it back then and thought it was a bit OTT - it would seem that it was a bit far fetched.
I don't mind helping people out, who need a helping hand, because none of us know if all, but the sheer number of posts got me thinking.... and then I went back to his earlier posts.
To be honest if I am unsure about something I am doing. I find it the fun part of researching the regs and learning it. Most times when you look things up yourself it will be committed to memory more than someone telling you
Reply to Using tp&n isolators in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I really can't see a problem with it assuming there is a neutral there.
Came across 3No 1ph heaters connected by 2xT&E cables from a 3phase supply on an installation whilst carrying out an EICR few years back...
