Connector blocks in DBs | Page 2 | on ElectriciansForums
Discuss Connector blocks in DBs in the Talk Electrician area at ElectriciansForums.net
beaten to it. 32A and the beauty is that, as thery're in line. 1 conductor each end, they's neater than wagos. line products do them, as do amazon and ebay.
Ideal Spliceline? In-Line Push-In Wire Connector - Box 100 | eBay
Are they 14.27 quid each or is that for a packet of them?
**edit** sorry, ignore that I see it's a box of 100.
I usually ferrule and heat shrink, always found it most reliable, quick, cheap and easy plus it leaves a very low profile connection not much thicker than the wire itself.
I suspect your definition of ferrule is somewhat different to ours then!
Reply to Connector blocks in DBs in the Talk Electrician area at ElectriciansForums.net
How many and what type of cables do you want to join, Chocbox is the last thing I would use.
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
