Install an electric shower in bungalow - price range | Page 2 | on ElectriciansForums
Discuss Install an electric shower in bungalow - price range in the UK Electrical Forum area at ElectriciansForums.net
E
electricnovice
Hello - member of the public here again, so please be nice this time :smartass:
I can appreciate people wont want to give out quotes on a public site, but if doable I'd appreciate a 'price range' if that's ok.
For an electrician installing an electric shower in my Mum's bungalow bathroom, so that when quotes come to her she knows they are at least in the right ball-park area. Job outline is -
Supply and install 10.5kw Triton electric shower.
10mm cable, 40amp MCB.
Plumbing-pipework, isolator and connectors.
Electrical installation certificate.
Sundries and labour.
(quote without the VAT)
Water to the shower to feed off from a cold water pipe which spurs off from an electrically heated water tank unit.
Thank you. Anyone's help is really appreciated.
SD (daughter) (Midlands)
Assuming...... Existing spare way on board, rcd, necessary bonding, I would estimate 4 hours labour + materials (cable, mcb, dp switch, 15mm supply pipe, stop cock and tap connector). Shouldn't cost more than £350 ( including EIC) imho.
Would you also notifying local building control for this price?
You claim no knowledge of electrics yet you have specified the cable size and mcb size?
Just have a look for the price of a triton piece of rubbish online if that's what you want fitted.
Can you not get a power shower fitted with a hot and cold feed from the water tank you mentioned? It would be a damn sight better than an electric shower
one like this is even cheaper:
[ElectriciansForums.net] Install an electric shower in bungalow - price range
£550 doesnt sound unreasonable. say £100+ just for the shower.
450 to include mcb,bonding, cable etc and possibly getting a plumber involved.
to give you an idea the last time i went to get a wylex breaker i struggled to get one for under £50 there were quite a few around £100 though
Reply to Install an electric shower in bungalow - price range in the UK Electrical Forum area at ElectriciansForums.net
