Dodgy trade pictures for your amusement! - 1 Million Views! | Page 33 | on ElectriciansForums
Darkwood
The two deep fat fryers ? in a domestic kitchen, add in the 3 electric showers 2 upstairs, one in the shower block of the pool, the water heater in the pool, the fans and pumps in the pool and a full electric cooker and you have a little more than 60 amps ?
oh and I forgot the bar outside as well
200 amps at a rough guess
I cant say too much about this one as its liable to go to court
[ElectriciansForums.net] Dodgy trade pictures for your amusement! - 1 Million Views!plumber had fitted another C/U from the existing, but had removed the meter cabinet to drop the cable to the shower into the cavity ?? then forgotten to reconnect the main earth
the whole thing was nasty
no CPC on the lighting circuit ( pre66) and metal fittings and switchplates everywhere
grommets absent on tails
DNOs earth pulled away from cable ??
lovely bit of termination aint it !!!
cold water feed to shower, missing cover and water flowed down into the terminals ?
oh and the shower switch was inside the shower as well
Heres a nice one
doing a favour for the family, I went to look at a house a young couple had bought, when I opened up the C/U all of these beads fell out, the main tails inside the C/U were melted due to polymer migration and high temperature
the origional cables had been dropped down in the wall cavity
as well as this metal light switches and fittings and no CPC and some amazine other bodges by barry the big mouthed know it all builder
where the new cables passed through a wall, the muppet had covered the big hole with a tin of PU foam and filler ?
There was an SWA in the garage, but no evidence of it inside the house, or a termination into PVC, until I lifted the floor and found this wonderful job
the C/U when removed showing damage to bus bars insulation
the C/u in the garage with the SWA nicely terminated
why me ??
Went to a commercial job, large equestrian building open to the public, owner decides on change of use, and adds a new door, now the sensible thing would have been to consult me first to relocate the fire alarm cables, no he cut them and joints them like this, and straight up baulked when I quoted 300 pounds to remove the entire section of cables and run new sections correctly
he also wanted me to install caravan supplies onto a wonky old fence ??and a few other jobs
I was polite but said dont waste my time
[ElectriciansForums.net] Dodgy trade pictures for your amusement! - 1 Million Views![ElectriciansForums.net] Dodgy trade pictures for your amusement! - 1 Million Views![ElectriciansForums.net] Dodgy trade pictures for your amusement! - 1 Million Views!
Lovely eh ?
supply cable to an outbuilding
in this case the client had called a builder in to convert the garage into a bathroom and utility room
his muppets fitted a new C/U even wrote out a ticket, but failed to test or inspect the existing circuits
then the problems started trippingout when it rained
and of course our team could not be located
I had to get the DNO to supply a new earth to the property as the muppets had failed to test it ( made the readings up)
replace the external supply, several lights and sort out the new bathroom
