AM3 Tails Stuffing gland | Page 2 | on ElectriciansForums
Discuss AM3 Tails Stuffing gland in the UK Electrical Forum area at ElectriciansForums.net
Gazthesparky
Glasgow
I seem to have a run of jobs of upgrading consumer units. Previously I've used 32mm standard stuffing glands for the tails when I have needed to. Although the sealing gland hasn't got specific holes for the tails i find that it seals well.
Anyway I've been looking at the special tails stuffing glands. My wholesaler is quoting alot for the metal wiska type. Looking at screwfix they have 2 plastic types. One is just the gland and one is a kit with a KEM adapter.
The only problem is that they need a 40mm hole and on the wylex boards I'm using have 20/32mm holes. So i would have to enlarge the holes to suit or buy the kit with the KEM adapter. Just wondering if anyone has any experience of these?
Just not sure because they seem massive in size any other suggestions what other people use ?
Cheers
I'd say that strictly speaking you'd only need a proper gland [and ideally additional fixings to secure the tails] on a TT system to negate the risk of the CU casing becoming live should the tails escape from the incomer [Highly unlikely I know]. Although I'll use a decent gland in all cases.
For most boards I do id say it tends to be either bottom or side entry and i use a 32mm stuffing gland. In all honesty I think tail glands are a bit of a con although the griploc one looks reasonable. If it was top entry i would use one to maintain IP4X. I wouldn't want to use a grommet as they aren't the best and they come out too easily. Nothing wrong with a brass bush and lock nut though if IP ratings are maintained.
Sorry, mate. That only does 2 x 16mm Tails and 1 x 16mm earth. Too small for 25mm tails.
Think Murdoch may have meant these:
40mm/32mm Tail Kit - 2 x 25mm Tail & 1 x 16mm Earth Cables - https://www.tlc-direct.co.uk/Products/WKTKP40R32.html
They have a 40 to 32 reducer included.
Out of interest has anyone successfully got 25mm tails and a 16mm earth through the 16/16/16 32mm glands. Bit of brute force through the gasket might do it if the gland body is wide enough..
Been meaning to load these for a few days I put the tails gland agenst the board to see for size. There's a 20mm stuffer and 20mm coupler just for size reference. The tails gland is massive so that is being sent back and I'm going to go for a 32mm stuffer for the tails.
[ElectriciansForums.net] AM3 Tails Stuffing gland
But you wouldn't get 2x 16mm tails in a 20mm stuffer would you? And if the tails are 25mm?
The only issue with the bigger gland is cutting the damn hole. But the bolt up plate cutters make quick work of it.
Reply to AM3 Tails Stuffing gland in the UK Electrical Forum area at ElectriciansForums.net
I doubt we would be recommending them if they were not up to the job
I think a 3 legged breakout boot would be your best bet in the circumstances.
davesparks
